Looking for a set of four front pads, nearly identical to CRG’s VEN99: The difference is in the spacing of the threaded holes for the retention bolts/springs on the back of the pads.
CRG used 64 MM for their own branded stuff. For others though, there were some differences. The kart I have uses the SAME pad, but the retention bolt holes are only 60 MM apart!
I have sourced rear pads, but the fronts are giving me headaches. One online vendor shows them here: http://www.kartpartsdepot.com/GP_Front_Medium_p/rkdpa48.htm
One who advertises with EKN has them here:
http://www.accelerationkarting.com/aagpfrontbrakepadset.aspx
Neither place can ship though, there is no availability.
Anyone have a set stashed, or know where I can pick some up?
