Home Forums Tech Talk water leaking at head bolts
Viewing 4 reply threads
    • #16132
      Aaron Smeenk
      When I run my PRD fireball I notice some water on one of the head bolts. I can see some white chalky stuff where it must be happening somewhat regularly. Is this normal? or should I worry about. Its not a crazy amount but if I put my finger on the one bolt its wet.
    • #16136
      Peter Zambos
      No, that is not normal.  Any amount of water is wrong.  That is, as long as it’s not raining.
    • #16141
      Aaron Smeenk
      How should I go about fixing it? top end rebuild?
    • #16165
      Lawrence Doty
      Should be an easy fix.
      There are 6 o-rings. 1 each for the 4 head bolts and 2 more for the head. There is also a shim under the small head o-ring.
      Drain the water, pull the head off, remove the old O-rings and check to insure you have the shim. Then just install the new O-rings, bolt on the head and refill with water.
      You should be good-to-go.
      I had the inner head o-ring go out on mine (turned the motor into a waterpump…). after replacing all the O-rings, and installing the shim that was missing, the motor ran great at the last race.
    • #16168
      Aaron Smeenk
      cool thank you!
