Home Forums Classifieds Classifieds – Parts Various TaG Kart Parts
    • #18400
      Chris Berg
      Below are a list of various kart parts we have for sale. We are asking $800 for the entire lot, and would like to keep from parting things out. However, if there is particular item you would like, please contact me.
      • XL Tillet Seat – Sold
      • Alum. Radiator – Sold
      • AMB yellow transponder (w/ charger) – Sold
      • Douglas Mag. rims with mounted MG rain tires – Sold
      • Douglas Mag. rims with mounted MG slicks – Sold
      • Dunlop kart cover – Sold
      • Lots of lubricants and oils
      • Exact Toe
      • Rear Gears (Alum.-71, 72, 73, 75, 76, 78, 79, 80, 84, 86) (Teflon – 73, 75)
      • Kart Racewear Seat Pad – Sold
      • Tire Whiz tire remover and mounter – Sold
      • Airbox cover and outer filter
      • Toe plates (Two sets)
      • Tire bag – Sold
      • IAME Leopard enduro clutch and drum – Sold
      • IAME Leopard 10t driver – Sold
      • #219 chain breaker – Sold
      • IAME Leopard starter motor end
      • Alum. lock collars (two)
      • Engine mounts
      • Alum. chassis mounting brackets (two)
      • IAME clutch puller – Sold
      • IAME clutch wrench – Sold
      • Tollotson 334A carb – Sold
      • #219 chains (Three) – Sold
      • Safety Wire – Sold
      • Spring puller
      • Pop-off gauge – Sold
      • Wheel nuts
      • Intrepid eccentric pills (two sets)
      • Fulcrum arm height gauge – Sold
      • Tie-rod ends (five)
      • Intrepid King Pin bolts (four)
      • IAME Leopard reed cage
      • Piston stop – Sold
      • IAME thermostat
      • MyChron large water temp sensor – Sold
      • Various Tollotson carb. parts – Sold
      • IAME Leopard clutch keys and bearings
      • IAME Leopard exhaust studs (three)
      • IAME Leopard ignition box rain cover
      • Outerwears MyChron rain cover
      • Intrepid bottom front bumper bar
      • Intrepid brake parts
      • Foam inner filter for airbox
      • Intrepid RF spindle
      • Tire bead breaker – Sold
      • Tie Rods (eight)
      • Intrepid/SKM alum. brake bleeder
      • Ratio Rite
      • Extra exhaust flex
      • ZoomBang seat pads – Sold
      • External starter – Sold
      Please let me know if you have any questions.
      NorthernLights Motorsports
      chrisbergracing.weebly.com
    • #19274
      Chris Berg
      To the top!
