Home Forums Tech Talk Vacumn fuel pump
Viewing 2 reply threads
    • #53115
      bo rougeou
      Would someone please describe the behavior of a Honda 125 when the fuel pump fills with oil?  Does it quit or is the fuel problem intermittent?
    • #53122
      Chuck Bunnell
      Oil on the pulse side will dampen the pressure pulse and change the response of the diaphragm.  I say pressure pulse because it alternates between a positive pressure pulse, piston moving down, and a negative pressure pulse, piston moving up.  There are a lot of “depends” here such as how much oil and what engine RPM, but the end result will be reduced pump efficiency.  So if its your supply pump you could run out of fuel in the carb or at least go lean, and the opposite if its your return pump assuming a pump-around system.  Ideally your pump(s) should be mounted such that any oil can drain out of the pump and flow back to the engine.
    • #53329
      bo rougeou
      Maybe I should check the ‘clock’ on the mounting .   Thanks
