Home Forums General Karting Discussion Unilli tires
Viewing 7 reply threads
    • #6957
      Dale Bert
      Has anyone run Unilli tires on asphalt? Everything I have found on them seems to suggest running them on dirt. At $99 a set of 4 I would like to try them.
    • #7033
      Do they make 5″ tires? All I found was 6″ tires that needed chemicals and cooking to make them work. Also they are low rubber like a tire that’s been cut down.
    • #7035
      Brian Mead
      Here’s the link to the 5″  Walt.  I wonder what they punch in at?
      http://en.unilli-tyre.com.tw/Tyre.aspx?c=105
    • #7037
      Brian Mead
      A little more reading on the site reveals that a sub of unilli makes them – the acme corp.
      no, I’m not kidding.
    • #7175
      A little more reading on the site reveals that a sub of unilli makes them – the acme corp. no, I’m not kidding.
      Then they should work great on my Coyote kart so I can catch the road runner.
    • #7202
      Dale Bert
      A Company that Makes Everything
    • #7251
      Looks like the 5″ tire sets have 3.60″ fronts. Might be interesting to try on a clone kart. They have a 4.50 but in a different compound with no rear tires and the UN-515 looks to be something for the vintage karts. The other tires on that page are 6″.
      I hope that max inflation number is the recommended running max, it would be hard to bead a tire at 20psi.
    • #9852
      Anyone try these things yet?
