Home Forums General Karting Discussion Top Kart chassis tuning guide
Viewing 12 reply threads
    • #28230
      Bjork Denil
      Hi,
      I just bought my first kart this last weekend from my local shop after driving rentals for 10 years. This was a pristine used top kart chassis with a rotax engine. The shop mostly deals with CRG, DR kart, gp racing chassis and they are very good at tuning those. However, top kart is new to them.
      So we were looking for a top kart specific tuning guide. Couldnt find it on the web or in the forums here. Anyone have any details?
      thanks
    • #28243
      Try this link; http://www.topkartparts.com/
      There is a link on the page to an email address for requesting information.
    • #28253
      You tune it like any other kart just use the CRG guide.
    • #28254
      Gary Lawson
      Its nice to have one from the manufacture to get a starting point especially. Also to understand how the axles are coded by color etc. Call grand products or top kart USA. One of them will have an answer for you or be able to answer any set up questions you have
    • #28289
      Definitely contact the guys at Grand/Top Kart USA as Mike T. has noted above me, but as a side note those KRacer videos are super good learning tools and explain a ton about chassis setup so those are worth a watch as well.
    • #28291
      Bjork Denil
      Thanks guys! Blake from Top Kart responded saying they are trying to have a tuning manual out by July. And I will watch the kracer videos – i have much to learn !
    • #28292
      The KRacer ideos are great, but currently the links to the videos are inactive.
    • #28339
      James McMahon
      I think I have the KRacer videos archived somewhere. Might ask Col if he’ll let me share them.
    • #28343
      Bjork Denil
      I can see the videos fine from the vimeo link in my post. Probably someone fixed it..?
    • #28487
      John Wehrheim
      Top Kart replied back with a standard setup for the 32 mm Speedy chassis.
      Toe out : 2-3mm total
      Caster Top: IN (dot towards front)
      Caster Bottom: 0 eccentric
      Front ride height: big spacer on bottom with the other 3 on top
      Spindle Spacers: 1Big (10mm) 2Small(5mm) inside of Front Wheel Hub
      Axle: Blue
      Rear Hubs: 98mm
      Rear width: 45.5-55 inches
      Rear ride height: Axle 3rd hole down (chassis high)
      It would be good to know your weight and height, plus the tires you plan to use.
    • #28497
      Bjork Denil
      160 pounds
      5 feet 9
      It came with MG yellows and I guess I am going to use those until I know better ..
    • #28519
      LOL, that’s like a 10″ difference, anywhere in there would be good?
    • #28520
      Craig Drabik
      I thought maybe he mis-typed and should be 54.5-55″?  Seems right with Yellows.
    • #28283
      Bjork Denil
      Hi again,
      I got a response from Mike from topkartparts.com link posted above:
      START OF RESPONSE ======
      As far as I know, there is not a chassis manual provided by Top Kart and I am pretty sure I would know if there was one. There really isn’t much difference in how you tune a kart regardless of the manufacturer. The difference lies in the fact that different chassis like different rates of lift depending upon the weight, track and track condition. Even different Top Kart chassis like different setups.
      What I have found to be most useful is a series of videos done by KRacers in Australia. They can be found at http://vimeo.com/kracer/videos and I suggest starting with the rate of lift video. It may not make total sense to you right away but as you look at the other videos, it will begin to do so.
      ============ END RESPONSE
    • #28285
      Michael Tetreault
      Bjork,
      I am not sure who you spoke with but I am the North American Importer of Top Kart we would be glad to assit you with what you are in need of.   You can contact myself at Grand Products Inc. Or our Distributor Top Kart USA and ask for Blake.
      Grand Products Inc 215-244-1940
      Top Kart USA 317-870-3122
      Website: http://www.topkartusa.net
      Michael Tetreault
    • #28297
      Bjork Denil
      Axle: Blue
      Rear Hubs: 98mm
