$3400, Located in Westchester NY
Selling my TonyKart Rotax Evo TaG kart. The frame is a 2016 401 and the bodywork and running gear is from a 2012 EVRR. I have always run the kart with frame protectors. Motor had a top end rebuild over the winter and now has 2 hours on it. Brakes are MCP and the master cylinder was replaced with a MCP billet m/c over the winter. The kart is quick and still responds well to chassis changes. Selling because I am buying a house.
Will also come with a spares package which includes the following:
Spare chain
Carb Jets
Spare PowerValve Solenoid
Powervalve bellows and blade
Spare exhaust socket
Spare exhaust springs
12t front sprocket
Fuel Line
Camber tool
Starter rebuild kit
Spare starter cable
Powervalve and crank sensor gaskets
2 batteries and charger (battery 1 may be on the fritz, it doesn’t take a charge well)
Motul chain lube
½ bottle if Rotax 2 stroke oil
Brake Fluid
Brake bleeder bottles
Spare ignition coil
3 rear sprockets
Also no pictured is a whole spare harness that was replaced by Rotax as part of the campaign (I never had an issue with it) and a MCP cast master cylinder.
*MyChron not included. Water temp sensor will be included*
Can also include the following:
Kart stand: $200
Trailer: $200
Alpinestars Kart Suit size 54: $100
Alpinestars Gloves: $50
Would do the whole package for $3800
Photos: https://photos.app.goo.gl/9qgJBDdsbYECf7Y8A
