Home Forums Chassis & Handling Tony kart rookie rain setup tag 60cc
Viewing 3 reply threads
    • #46012
      Mark Parker
      Looks like we have some weather rolling in this week, need a brief bit of basic help from someone with otk rookie kart specific knowledge
      widen the front to the max?
      narrow the rear (how much)?
      ?psi of air?
      axle, we run N in dry?
      how many teeth up on gear?
      anything to the seat? Pad ? Move weight?
      Castor pills?
      alignment?
      anything else?
      thanks guys
    • #46024
      Matt Dixon
      Rear width should be the same as front if possible.5
      Up on air over 20
      U axle
      Add many teeth
      Raise and move seat forward
      Toe out
      Disconnect seat struts
      94y
    • #46123
      Mark Parker
      Anything with Ackerman? Ride height?
    • #46220
      Matt Dixon
      As for motor lean it out a little because you wont be twisting it so much…
      94y
