Home Forums Chassis & Handling Tillet seats question for chassis tuning
Viewing 3 reply threads
    • #7394
      Bob Baldwin
      Blocked
      I had posted a question in General Karting section and probably should have posted it here . I would like some opinions on the topic . We all know seat placement factors into chassis tuning and yes an upholstered tillet seat sized right to the driver would be a good thing . However looking at their website they seem to make the same size but with different flexible characteristics such as Flexible and Stiff . I would think you would want the Stiff one if only from the standpoint that it would help to raise the inside rear wheel while you are cornering .If that is correct why would you want or need a Flexible seat ?
    • #7396
      Just like seat placement or axle stiffness, seat stiffness is a tuning tool. Some taller drivers might want to switch seat stiffness if they think they are getting too much inside lift. A smaller driver might want a different kind of stiffness in the seat to get more weight transfer.
      I know of a couple guys who have tuned almost solely by seat stiffness and placement.
    • #7402
      Bob Baldwin
      Blocked
      TJ : I can understand the stiffness of the seat helping to raise the inside rear wheel . Can you site me an example AND explain to WHAT point do you determine if you are getting TOO MUCH LIFT ? . Or where you can get by with a flexible seat ? Lets face it I would venture to guess that most guys 90% have only 1 seat for their kart . The quality seats don’t come cheaply .
    • #7406
      Well if you’re getting too much lift, the kart will either overload the outside rear and you’ll start sliding as the tire loses traction. Typically you’ll feel it lift on turn-in, and as it reaches it’s height, you’ll start to feel the rear slide and you’ll start to counter-steer, setting the inside rear down and making the kart flat-slide.
      Too much lift can also cause the rear to break traction on the outside rear and cause the kart to hop a bit too as the rear grips and releases and repeats.
      I can’t tell you specifically when you’d make a seat change like that since I also only  use one seat in one stiffness all the time and I’m small so I always need to find lift.
      My guess would be that the soft seat works better for tall guys when the grip comes down and they need the softer seat to absorb some of the weight transfer. But I’m not positive.
