Home Forums TaG TAG – Leopard – Flex length tuning
Viewing 3 reply threads
    • #46560
      Samir Shah
      Hi.
      Since I have 2 used Leopard engines, I also have used flex for the exhaust header. Both engines came with different length flex – 1 is 49mm, the other is 64mm.
      I’ve read about people ‘tuning’ with the length of the flex. Can people share their experiences?
      I’ll be running at 2 local tracks in the New York City vicinity – Englishtown, and OVRP – Oakland Valley. Both similar in length.
      I’ll appreciate any education, theory, and suggestions about what length of flex to use at these tracks.
      Thanks, Samir.
    • #46572
      Short flex = more top/bottom end power
      Long flex = flattens the power curve out and lets the engine pull harder in the mid-range
      Use short flex when you’re running on a track with a long straight or tight curves and you’re revving the engine hard.
      Use a longer flex when the track is more flowing.
      In Sr. we almost always use a short flex.
    • #46573
      Samir Shah
      Thanks. I’ll have my son test both flex, and see if he can make out the difference. Since we’ll have a restricted header, it could be interesting.
      On a related note, is the silicone sleeve over the flex needed? Can I use either nothing, or header wrap? I see exhaust gas leaking from that area, will it make a difference?
      Thanks again.
    • #46625
      The sleeve isn’t needed but it’ll help keep the back of your kart clean rather than covered in oil from the header.
      It won’t make any difference.
