Rear Axles, Hubs, Keys, Gears
30mm Axle Keys (fit Shockwave & PKT Axles) Narrow 6mm (4) – $2.50 each
30mm Axle Keys (fit Shockwave & PKT Axles) Wide 8mm (5) – $2.50 each
Shockwave 30mm Short Rear Hub – $40 a pair
Shockwave 30mm Medium Rear Hub – $40 a pair
Used Hortsman Spilt Gears (81,87,89) – $5 each
Used Hortsman Gears (89(2),91,92) – $5 each
Used Righetti Gears (90,91,92) – $5 each
New Righetti Gear (90) – $7.50
Clutches
Used Comer Blueprinted Clutch – $40
Comer used 12 tooth driver (2) – $20 each
Front End
Shockwave Cadet Spindle (left) – $10
Cadet spindle (left) – $5
Tie Rod Aluminum 220mm (3) – $4 each
Tie Rod Aluminum 210mm – $4
Tie Rod Aluminum 205mm – $4
New 17mm Bearings (10) – $2.50 each
Miscellaneous
Pedal Extenders Brand New (2 pairs) – $35 pair
Comer Spark Plugs (used but good) NGK BP9HVX (8) – $5 each or $35 for all
28-30mm Engine Mount Clamps Shockwave (2) – $4 each
28-30mm Engine Mount Clamps Odenthal (8 ) – $4 each
Used old style HPV-1 Pipe (excellent shape) – $10
Bell Racing Shoe (Black, size 6) – $5
HMS Racing Shoe (Black, size 6) – $3
GForce Racing Shoe (Black, size 9) – $5
