Hi Dillon
I would recommend a 7mm O/D high performance double insulated racing HT lead with copper core.
The core should be made up of 40 strands of 0.25mm copper (or similar).
Plug cap should have a 5K ohm resistance (NGK LB05EMH or similar) and you should always run an Iridium resistor racing plug with a fine wire ground-strap (NGK R7376-10 or similar).
The resistor plug and cap cut down electro-magnetic interference that can affect the CDI box
Best Regards
Ian :-)
