Home Forums Chassis & Handling Sniper Linear Camber/Castor Adjusters ?
Viewing 4 reply threads
    • #9374
      Keith
      What kind of modifications does it take to make sniper camber/caster adjusters work on a 04 crg road rebel?
    • #9375
      Keith
    • #9652
      What size kingpin do those come with?
      I’m not sure the [ is big enough to support the sniper system
    • #9914
      The problem with most karts is that the yoke is not big enough to fit the sniper system. You would have to weld in a piece around the existing upper structure smooth it all out and mount the sniper pill.  If you can do that or get it done it is the best front end adjustment system I’ve seen.
    • #9919
      A set of these:
      XV Racing Products
      http://www.xvengineering.com/
    • #9966
      Keith
      Does somebody sell those or did you make them?
    • #10016
      Yes and yes…
      CR
      XV Racing Products
