Home Forums Tech Talk Safety clips/circlips
Viewing 6 reply threads
    • #25690
      Dustin McGrew
      I have a Birel kart and it has these safety clips.. http://cometkartsales.com/8mm-Safety-Clip.html
      The price on Comet’s site for them seems insane to me. $1 for that tiny piece of metal? Is there something that is better and cheaper than these clips that I could use?
    • #25693
      Rick Brown
      Cotter pins or saftey wire
    • #25764
      Stu Hayner
      After working on and building many brands of karts, I welcome those pricy little Birel clips. I wish every kart used them.
      You will break countless bits trying to drill bolts, then ruin every nylock you put on that drilled bolt. When you snag an arm on a cotter pin or safety wire, you’ll be more than glad to pay that dollar a piece for that little clip.
      I think of it this way. If I bought a set of new clips every year we’re talking about less than a $20 bill.
      To me, that’s a pretty fair price for the easiest clip in karting.
      Just my $0.02
    • #25766
      Gregg Palmer
      I agree with Stu.
    • #25904
      Dustin McGrew
      Thanks guys. I think I’ll stick with the circlips. Now what happens if I break a bolt? I can’t find bolts with that groove in them anywhere..
    • #25911
      Then you will have to get a regular high tensile strength bolt and learn to drill a hole without breaking the drill bit, dress the threads so they don’t cut into the nylock and install a cotter pin so it doesn’t snag on anything.
    • #30290
      brian downing
      simple folded safety wire
      Regardless of how one creates the hole, in the end safety wire is the easiest, cheapest way to create a lock. A can of safety wire costs $15 and lasts years. Invest in a good set of pliers, a worthwhile spend.
      To prevent the snags and impaled fingers, always leave a short bit of extra twisted wire at the end and fold the sharp end back on to the nut or bolt so that it’s not exposed.
    • #25702
      That tiny piece of metal is chrome plated European music wire.
      Seriously you can drill a hole for a cotter pin where the slot for the clip is. Just file a flat so you can get the drill started and try to stay on center. Don’t drill too big.
      Insane prices, welcome to karting.
