Home Forums General Karting Discussion Rotax Starter
Viewing 3 reply threads
    • #10471
      Ambrose Buldo
      New to Rotax… Dumb question.
      With the correct sized socket at the end of my remote coleman starter, can I use a external starter to start my rotax like I can with a Leopard?
    • #10519
      You are not going to have starter problems you had with a Leopard. Have a fully charged battery and a spare. Rotax engines do not recharge the battery. You will have to learn how to jet the carb and you are good to go.
    • #10794
      Keith Buffo
      I don’t see why not… and I’m pretty sure I’ve seen it done.
      Back when I was new to Rotax, not only did my onboard starter fail, it failed to stay on the kart! Not too good. After I got done nut-n-bolting the whole kart, I bought one of these: http://sharkshifter.com/zc/index.php?main_page=product_info&cPath=137_140&products_id=597 I give my starters two seasons, then ready or not I replace them with $100 aftermarket. I’ve never had an issue, but bring one of the old ones to the track every anyway.
    • #10863
      Ambrose Buldo
      Thanks that is the answer I was hoping for…
    • #10562
      Ambrose Buldo
      Appreciate the feedback. I have a new Lithium Battery, that I keep on the Kart well charged and a spare Conventionial Battery.  With a total loss system in the Rotax, I understand the need to keep battery charged.
      Hopefully starter won’t fail. Question is, if the starter were to ever fail, could I start by attaching the starting from the starter nut? If not’ I’ll dontate my Coleman external starter to someone who could use it.
    • #10852
      Chad Landers
      Yes, you can start the Rotax with an external starter.  You will probably never really need to,but if you already have one I’d keep it on hand.  You just need a 17mm socket.
    • #11765
      Someone told me that nut is not meant to take a starter gun but you can use it in a pinch.
