additional notes:
cylinder – 001104L9
8.5carb
motor package available with the following NEW parts:
qty Part# Description
1 non-rotax 13T front driver – AFAM
1 Pfiefer 18T belt drive sprocket
1 236415 12T front driver
2 938795 exhaust spring
2 224389 reed valve assy (reed cage – complete)
1 659907 clutch
1 223993 cylinder ‘a/b’ sr 2009
2 223997 cylinder ‘b’ sr 2002
1 613106 head cover w/o thermostat
1 296292 piston kit – 53.97
1 296293 piston kit – 53.98
1 296291 piston kit – 53.99
1 296161 cylinder gasket set
1 296160 case gasket set
1 650481 base gasket .5mm
2 650483 base gasket .4mm
2 650480 base gasket .3mm
2 431337 base gasket .2mm
2 650482 base gasket .8mm
1 295922 radiator assy
2 224666 radiator mount plate
1 266125 wiring harness
1 265580 start button
1 265592 on/off switch
1 242925 clutch drum nut (back side)
3 242091 clutch driver nut m10
1 632415 short needle bearing
3 627345 clutch thrust washer / thin 11t
1 627340 clutch thrust washer / thick 12t+
5 296165 fuel pump gasket set
2 293834 carb rebuild gasket set
3 268042 carb sleeve (filter)
1 281470 carb jet kit
5 250231 power valve gasket
1 260723 power valve bellows w/spring
motor with above listed parts = $3800.
