Home Forums Classifieds Classifieds – Parts Rotax Max parts – NEW sell out
Viewing 3 reply threads
    • #6097
      Eric Chappell
      email – dceric@yahoo.com with any questions….
      Low hour complete motor package also available if interested. Double sealed, with passport. Multiple race wins (road race and sprint), multiple RIGP podiums…fast, race ready motor. – $2500 complete.
      Rotax parts listed below are all new, never used. Take 30% off prices noted below.
      $3000 takes motor package and all parts listed + 1 set of mojo ties and a few other misc Rotax parts not listed.
      qty Part# Description Price
      1 non-rotax 13T front driver – AFAM $25.98
      1 Pfiefer 18T belt drive sprocket $40.00
      1 236415 12T front driver $40.00
      2 938795 exhaust spring $5.00
      2 224389 reed valve assy (reed cage-complete) $85.58
      1 659907 clutch $168.90
      1 223993 cylinder ‘a/b’ sr 2009 $699.00
      2 223997 cylinder ‘b’ sr 2002 $200.00
      1 613106 head cover w/o thermostat $125.00
      1 296292 piston kit – 53.97 $127.05
      1 296293 piston kit – 53.98 $127.05
      1 296291 piston kit – 53.99 $127.05
      1 296161 cylinder gasket set $43.31
      1 296160 case gasket set $60.00
      1 650481 base gasket .5mm $4.47
      2 650483 base gasket .4mm $4.47
      2 650480 base gasket .3mm $4.47
      2 431337 base gasket .2mm $4.47
      2 650482 base gasket .8mm $4.47
      2 224666 radiator mount plate $10.99
      1 266125 wiring harness $164.60
      1 265580 start button $23.67
      1 265592 on/off switch $33.42
      1 242925 clutch drum nut (backside) $15.00
      3 242091 clutch driver nut m10 $1.00
      1 632415 short needle bearing $16.00
      3 627345 clutch thrust washer / thin 11t $2.50
      1 627340 clutch thrust washer / thick 12t $2.50
      5 296165 fuel pump gasket set $20.72
      2 293834 carb rebuild gasket set $20.00
      3 268042 carb sleeve (filter) $12.88
      1 281470 carb jet kit $29.50
      5 250231 power valve gasket $3.85
      1 260723 power valve bellows w/spring $18.60
      **updated jan 12,2014**
    • #9384
      Dennis Chappell
      Lot of parts left.
    • #17405
      Eric Chappell
      Package was on hold awaiting payment – this complete list is now available again!
      Let me know what parts you want – or – make an offer on the complete list
      dceric@yahoo.com
    • #19463
      Eric Chappell
      List updated
