Home Forums TaG Rotax Max Rotax Carb Cleaning
Viewing 2 reply threads
    • #28643
      Mike Bray
      Looking for opinions on best methods to clean Rotax carburetors.  Straight carburetor cleaner?  Ultrasonic cleaner?  If UL, what solution works best?  Any experience you can pass along will be appreciated.
    • #28646
      Mike,
      If you’re starting with a clean carb, cleaning it with carb cleaner will work well if done at the end of the session day. Don’t have an ultrasonic cleaner, but it probably is the best method.
    • #28671
      Steen Carstensen
      Make sure to remove the needle valve before you spray the carb with brake clean, or you WILL have to buy a new one.
      • #29194
        Scottie Melancon
        Yes! Always make sure to remove the needle valve when cleaning.  I’ve toasted two engines in the past by not doing this.  Also, soak a q-tip
        with wd40 and swab the needle valve seat before replacing. This helps initial lubrication of the seat. The carb cleaner can dry out the seat potentially causing the needle valve to stick during startup after cleaning.
