Home Forums General Karting Discussion Recommended fuel and oil?
Viewing 3 reply threads
    • #46018
      baruch fishman
      Hi guys,
      I have a early margay kart with PRD Leopard engine.
      Which racing oils would work best , i know from past experiance with kt100 we used to use MOTUL oil? and what kind off fuel should i use?
    • #46020
      Keymaster
      Hi Baruch,
      The PRD is different from the Leopard. Just so you are aware.
      The Motul oil can be used for TaG engines, such as the PRD and Leopard. Check with your club or track to see what fuel is legal, as some specify which fuel to use. Sometimes, they may also spec the oil as well.
    • #46022
      baruch fishman
      Thanks will do!
    • #46023
      Matt Dixon
      Run the fuel and oil you are going to race.
      94y
