Home Forums General Karting Discussion Question involving setup
This topic contains 1 reply, has 2 voices, and was last updated by  Tim Koyen 5 years, 8 months ago.
  • #15706
    Brandon Ryan
    Watching the Grand Nationals coverage, and being a completely new person to kart racing in general, I had a question about setup.
    So in lieu of recent events, where practice, qualifying, and and the first couple heats were run on a dry sun baked track, and today looks to be going to be ran on a overcast, rainy, and wet track.
    My question is, besides tires, what set up changes do you make in an event like this? I know when racing scca, I would remove front end toe, and camber to make the car easier, and more predictable to drive.
    I am just trying to learn as much as possible, since the sunshine state likes to have un predictable rain storms between 3-5pm everyday in the summer.
    Thank you in advance,
    Brandon
  • #15729
    Tim Koyen
    Good questions Brandon.  The extent to which you make the following changes will all depend on what level of grip exists between just a damp track and a full out-water-flowing-across-the-track rain setup.
    Increase caster
    Widen front track
    Narrow rear track
    Raise center of gravity – raise seat/driver and/or ride height
    Move weight forward on kart
    Loosen floorpan and/or seat bolts to increase chassis flex
    Loosen front bumper bolts
    Increase Ackermann in steering
    Axle change
    Bigger front wheel hubs
    These are the things I work with.  Depending on the rain conditions, I may do them all, or only a couple.  Sometimes all a damp track needs is rain tires and maybe a little different track width.  The kart can only make up for some of it though, and a good driver who has logged some miles in the rain can do way more than the kart can, in my opinion.
    The object of all these changes is to get the front end to grip enough to turn the kart, then  keep the rear from coming out in the turn.  Much like it is in the dry, only more extreme.
    I’m sure some guys have more suggestions, as well as driving tips for the rain.  I’ll leave the driving to them, I’m only the mechanic/tuner.
    KartLift Kart Stands
    DeepSeat Kart Seats
    877-777-8020
