Home Forums Classifieds Classifieds – Engines P1 X30 Engine Package With Spares $1850
    • #100889
      Chris Watts
      Complete IAME X30 engine package for sale with spares.  Engine has less than 7 hours.  Asking $1850
      – Includes everything required to race
      Engine, airbox, wiring harness, radiator & mount, water pump with mount, thermostat housing with temp sensor, water pump pulley with drive belts, header with temp sensor, pipe, OTK pipe mount and all necessary hose clamps, springs, etc.
      – Spares included
      Tillotson carburetor rebuild kit
      Tillotson needle valve kit
      starter brush set
      spare reed
      spare reed cage gaskets
      spare carburetor gasket
      2 exhaust gaskets
      spare exhaust header without temp bung
      10 tooth driver
      2 spare clutch needle bearings
      brass water/air purge with gasket
      2 spare water pump drive belts
      2 gently used 219 chains
      5 used but cleaned NGK plugs differing temp range
      Buyer pays shipping.  Call or text Chris at 281-414-9139
    • #100907
      Chris Watts
      Engine is sold.  Thank you ekarting!
