I have 2 engines. On one, which we raced, the header at the restrictor/flex is nice and dry and brown.
The other one, which I had a hard time starting, but now have running thanks to an external starter, is oozing a ton of black oil at the header/flex. Is this from a) all my failed starts that flooded the engine b) normal c) my fuel is not mixed anymore from sitting, and the oil has separated from the fuel? Or is this symtomatic of a bigger problem eg rings being loose?
Can this excess oil damage the exhaust pipe? Should I use 2 different pipes for each engine too?
Thanks, Samir.
