Just purchased a CRG with Maxter ICC motor for recreational use. I have been skimming the internet for info on these engines with little luck. I am looking for info on running, maintenance, rebuild, carbing, troubleshooting, etc. Any books I should pick up? thanks!
There are no manuals or much you will find on the internet. The knowledge on these is all with the engine builders. I have a maxter also and its a great engine. But I do my rebuilds with Joe White at JWR. I can just ask him all the questions you had. Swedetech would be the same way. In general this is the way it is with most karting engines,
Welcome to some of the most fun you can have on 4 wheels. But as Keith has stated there are no manuals for set up. There are programs for jetting but you need to set a baseline first before it is accurate. Richer than you need to be works well. These engine has a considerable amount of over rev. But my advise would be not to max out rpms and it will live for a ling time. What area do you plan to race at? If your with ces series in the midwest would be glad to help you out. As far as maintenence it`s hard to say. If jetted nice and not over reved a piston every ten gallons will probably go a most of the season. To be safe a lower end 1/2 way thru season. Have fun
