Home Forums General Karting Discussion Need Help Identifying CRG Axle
Viewing 2 reply threads
    • #10783
      Todd Kageals
      Guys,
      I have a 2011 GP10 and I believe I bent the axle.  The right rear wheel is not turning true, it follows just a slight ellipse.  I removed the hub and the bare axle does the same thing so I am fairly sure it’s bent.   I want to go ahead an replace it but I don’t know what’s on there.  It’s black, says “CRG Racing” and is about 2.22mm thick at the end.  My kart is setup for Stock Honda.  Anyone know which axle is in there and where I can find a reasonably priced replacement?
    • #10793
      Keith Buffo
      The axle ID is under the key for the left hub.
      It doesn’t sound all that bent, probably can be fixed well enough… a descent back up axle can be a day saver. Indicate where you are located, and maybe someone will point you to a great kart shop near you who can sell you a new one, straighten your old one and be there to shave your hide another day. If they attend the same races as you, all the better.
    • #11778
      Todd Kageals
      Keith,
      Thanks for the info.  I located the axle numbers M20+R and I ordered a replacement.  Any advice on the installation?  Never removed it before.
