Home Forums Tech Talk Mychron GPS
This topic contains 8 replies, has 8 voices, and was last updated by  Larry Andrews 5 years, 3 months ago.
  • #17165
    Gregg Hall
    Hello,
    I AM LOOKING AT BUYING A GPS UNIT AND WAS WONDERING HOW GOOD/EASY THEY ARE TO USE? ANY HELP WOULD BE GREAT.
  • #17166
    Ray Lovestead
    Hi,
    IT’S AN AWESOME TOOL.  IT’S AS EASY AS CONNECTING IT TO THE MYCHRON 4 AND JUST DRIVING AROUND.  THEN YOU DOWNLOAD IT (NEED THE KEY) AND CAN REVIEW ALL SORTS OF DATA (YOUR DRIVING LINE, LATERAL ACCELERATION, ETC.)
    "Karting Expert Since 2015"
  • #17183
    Mike Clark
    The only thing I have heard negative (from 1 person) is it eats the battery in the mychron. Is that true?
    I’d swap out a 9v battery for good info anytime.
  • #17213
    Ray Lovestead
    A single 9V will last for a day or two of driving.  So $2 a day to use it.  There are hooks on the extension box that comes with it to put in a larger battery, but so far I’ve not found replacing the battery to be that big of a deal.
    Ray
  • #17215
    Alan Michel
    Buy it.  you won’t regret it.
    Battery:  as Ray said..     not a big deal.   One 9V lasts me around 9-12 sessions.    I used one batterty for the first 3 days of Supernats, one for the last 2 just to be safe :)
  • #17523
    Jim Russell, Jr
    It is a fantastic tool for helping to improve your driving and setup of the chassis. Works really well if you have team mates you can share data with to compare against.
    Plan on 1 new 9V battery per race weekend. We have found the Werker batteries to hold up the best for power and vibration.
  • #18395
    Eric Stockford
    hey All ,
    Got the GPS for Christmas.
    The manual doesn’t say anything about a secondary battery but it comes with leads?
    Do i need to run a secondary battery?
    Can i use it with just the 9 V?
    What does it take for a secondary battery?
    Any help would be great, heading to Daytona tomorrow,  so looking for answers
    Eric
  • #18396
    Matt Dixon
    Just take 3or 4 9volts to Daytona and you will be fine.
    94y
  • #18458
    Larry Andrews
    The lithium 9V batteries last a lot longer than alkaline.
    I use a pack of 6 AA lithium batteries taped up behind the nassau and connected to those leads and rarely need to think about batteries anymore.  <shrug>
    http://www.ebay.com/itm/Black-9V-6x-AA-Size-Battery-Holder-Box-Case-With-Cover-ON-OFF-Switch-Wire-Lead-/190997531270
