Home Forums TaG Rotax Max MicroMax rebuild
This topic contains 3 replies, has 3 voices, and was last updated by  Thor Mauthe 5 years, 3 months ago.
  • #16694
    Thor Mauthe
    My son is running MicroMax this year and with the introduction of the Rotax series in SoCal I’m thinking that I may have him run Rotax one more year instead of switching to the MiniRok. I need to have the engine done, but I know that Rotax motors are pretty good at lasting. How often (hrs) do I need to get the bottom and top end rebuild. I know the top needs it, but I’m not sure how often the bottom does. I’ve looked but haven’t found what I’m looking for in the forums. TIA
  • #16854
    Mike Clark
    Thor,
    Not very detailed but, see pg 35 of this:
    http://www.rotax-kart.com/upload/files/71.pdf
    More downloads here:
    http://www.rotax-kart.com/en/Products/MAX-Engines/2-125-MICRO-MAX
    At least it seems to be a very lightly stressed engine.
  • #17163
    Marshall Martin
    I question whether you could ever wear out a Micro Max motor.  I know we have run Juniors 60 hours and Mini Max motors could go that long and probably longer.  Considering a Micro Max rarely goes above 10k rpm for a motor that is designed in the hardest use (Senior and Masters classes) that can go 40-50 hours I guess a Micro Max motor could last 80-100 hours.
    Marshall Martin
    http://www.lsrmotorsports.com
    Marshall Martin
    -marshall@lsrmotorsports.com
    -www.lsrmotorsports.com
  • #17164
    Thor Mauthe
    Thanks for the info and the PDF from Rotax. Amazing that the Rotax motor isn’t more popular in the US, well at least in the west where I live. Hope the SoCal Rotax series takes off for next year.
