Home Forums Briggs & Stratton 4-Cycle Racing Briggs Animal Max Power indicator
Viewing 3 reply threads
    • #47062
      Tony Wayne
      When fine tuning with head temp (under the spark plug pickup), what is the ideal temp range to be in?  And is that target temp always the same for all animal classes?
    • #47082
      Bernie Lacotta
      It varies a lot just by driving style.
    • #47146
      Steve Baker
      The cooler the head and the hotter the oil makes the most power.
    • #47188
      James Frantz
      What Steve said is easily demonstrated on the dyno. Cooling the head by any method will always show better HP numbers.
      I have a minimum of 3 temp sensors that i use on my dyno. 1) cylinder head temp 2. Lower block / oil temp 3. Intake air temp
