Home Forums 250 Superkarts Anderson Steering Hub 19mm? Looking for Driver's Bubble Bracket
Viewing 9 reply threads
    • #7120
      Mark Jauregui
      Hi,
      The steering hub that came with the kart when I bought it (20mm) seems fairly loose on the steering shaft and regularly requires retightening. Can anyone confirm that the steering hub should be a 19mm not a 20mm? If so, any recommendations on where, other than ordering from Anderson, I can find a 19mm hub with clutch lever? I’ve found 20mm hubs with clutch levers, but not 19mm.
      I also need a driver’s bubble bracket that is more bracket than welding wire.
      Thanks!
    • #7196
      Mark, a measuring device is your friend……  Last Anderson steering shaft I looked at was 3/4″, about 1 mm smaller than 20 mm.  If you have a clutch on the steering hub, Anderson used to bush the 20 mm hub and bore it to 3/4″.  I have a fixture to doing mine in the lathe.
      CR
      XV Racing Products
      http://www.xvengineering.com/
    • #7231
      Jim White
      You know Mark I think Chris is right. I remember last time I had mine off it had a thin shim between it and the hub. I just thought the prior owner had made something to adapt a different hub on. Maybe it was OEM Anderson afterall.
      Jim
    • #7252
      Mark Jauregui
      Thanks guys that makes some sense. I’ll see if I can rig up a 1mm shim.
      Any solid driver’s bubble brackets laying around out there?
    • #7260
      Tony
      Hey Mark – I have a new Anderson buble braket I tried to use on the ZIP Eagle II I sold, I will sell it to you on the condition that you get your ASS down to Buttonwillow and race!!! :)
    • #7300
      Mark Jauregui
      You are a legend! :)  What do you want for it kind Sir? (PM me)
      I would love to be able to accommodate your condition of racing at Buttonwillow, but am heading to Japan on Tuesday for a week. However, I will be able to put it to good use and attempt to dazzle you with my driving skills (or lack there of) at Sonoma. Would that work?  :)
    • #7308
      Mark Morrison
      Tony I will be there now We think we got the bugs fixed so look out itwill take you longer to lap me this time LOL
    • #7312
      Tony
      No deal Mark!! Screw work and flying to Japan! Racing is way more important!!!
      Mark I am so glad you have sorted your motor out and coming to Button!! No chance of lapping you now, all you Honda guys are flying!!
      Just kidding on the bubble bracket Mark – let me see what I paid for it and I will let you know.
      Larry you better get your finger out and get that motor back on the kart! No wait a minute, what am I thinking! You will have to ask Mark M to come over and help you find your spanners as you don’t know the difference between metric, american and good old whitworth!! Ha ha :)
    • #7336
      Larry Dobbs
      No package in the mail so I can’t put my motor together and back in yet!  As for which spanner to use, well that’s easy, the one that fits Wanker!  Ok, Wanker might be a little harsh let’s go with lima bean :O
    • #7375
      You can’t shim it to 19mm, it will be a .5mm shim, about .020″, that’s too thin.  You have to bore it larger, press a heavier tube into it, then bore that to 3/4″
      CR
      XV Racing Products
