Home Forums Briggs & Stratton 4-Cycle Racing Briggs LO206 Lo206 + Intrepid Crusier
Viewing 4 reply threads
    • #42920
      Troy Berry
      I am putting together a 2008 Intrepid cruiser with a Lo206. Any insight on the set up and handling of this chassis with a 4 cycle on a Medium grip Sprint track? We are running Jr. 2 (310 lbs) and I’m looking for any baseline chassis set up info. Thanks!
      "The Art is in the details"
      BirelArt AM29 LO206
      Intrepid Cruiser KA 100
    • #43018
      Jon Romenesko
      What kind of tires?  That’s going to make the biggest difference, IMO.  Generally i’ve found that i’m constantly trying to find ways to remove rear grip and free up the chassis.
      GP10/CR125
      http://theslipangle.com/
    • #43021
      Troy Berry
      Perhaps I should add a little more info on what I’m thinking to get any thoughts. We run the Bridgestone YHC. Typically at our track it’s about 13-15 psi. I am using DWT MAG LV.  My kid(driver) is 5′ and 125 lbs. Going to mount the seat as far forward as possible, bottom flat and even with the bottom of the frame rails. No crossbars. Rear ride height  set at max. up.  Rear axle is soft. Front set up neutral. Our track is 7/10’s of a mile., long straight, 2-3 sweepers and 2 tighter (slower) corners. Gearing will start around 15/57.  Thanks!
      BirelArt AM29 LO206
    • #43033
      Gary Lawson
      I’d say you are at a good starting point. I’d put the ride height centered to start and don’t be afraid to go s little lower on pressures for longer races. I’d also run a few millimeters negative camber and try taking some caster out as well.
    • #43080
      Troy Berry
      Now that’s what I love about this sport. Getting solid advise from a major karting champion……priceless. Thanks Gary!
      BirelArt AM29 LO206
