Did you get the setup sheet that says 4.11? I have mine set up pretty close to the base setup on the sheet. If not email Margay and ask for it.
What tires are you using? Your post doesn’t say. If they are a hard tire like the YDS I’m right at the widths front and back as the setup sheet says.
But for a softer tire like the YHC I’m about an inch or more wider front and rear.
No front bar, spindles in the middle. Caster is a little negative and just a touch of Camber using a Sniper Laser. Short rear hubs and medium axle. I’m using hub mount front rims.
