Help! My Leopard starts when I use the external starter, but not with the push button box. Worked fine last year, went to start it this year with a fresh, fully charged battery and it would not fire. New plug, and everything else you could think of. Even bought a new battery that cranks it 3 times faster than the usual batteries do. Even checked for spark, none. Put the external starter to it, and boom, fired right off. Replaced the push button box, and fired right off. tried again 10 minutes later and nothing. No spark again. External starter cranks it right off. Put a spare stator on, no spark using the box, fires off with external, tried another box, and it fired up, shut it off, and then it wouldnt start again. Are these stators bad and frying these boxes? Is there a way to check these stators to see if they are good before I fry another box? Boxes work for one start time, then they dont, spare used stator, box works and then it dont. HELP!
