Home Forums TaG Leopard Clutch Drums
    • #46283
      Samir Shah
      Are the 4-bolt (for the sprocket) Leopard clutch drums interchangable with the 3 hole drums of the early Leopards? I discovered that my track suppliers did not have new 3 bolt sprockets in stock, and am thinking I should switch to a 4 hole drum, or at least have one as a spare in case I have sprocket problems again.
      Secondly, assuming the 4 hole drum will fit, will it be legal to use the later drum in an earlier engine?
      Thanks, Samir.
