Home Forums Tech Talk leatt neck brace questionne
This topic contains 1 reply, has 2 voices, and was last updated by  Peter Zambos 5 years, 8 months ago.
  • #18267
    Sean Ranchbari
    hello
    i just got a 2nd hand leatt motokart in size medium, seeing as my sizing called for s/m in the larger range. however, to my dismay, the brace is about a half inch too large and i am using the 0mm spacing pics and thoracic brace on the best setting.
    is there any hope, other than missing the wedge for the thoracic brace, which would probably not help much, i cant seem to find any areas that can be tweaked for adjustment
  • #18843
    Peter Zambos
    You should really consult Leatt directly for sizing.  That being said, make sure you are trying on the brace with all of your gear on, as that will make a difference.
    Also, I don’t think it’s the wisest to purchase your safety gear second-hand.
