Home Forums Tech Talk Laydown Enduro – 5" or 6" wheels
Viewing 6 reply threads
    • #51580
      Daniel Justice
      We are putting together a laydown kart to be race ready and we are trying to decide new wheels.  Most say to run 6″ wheels at least in the rear, but I’ve heard many different opinions. We are considering 5″ all around, but I’ve been told it may not be advisable. We are running Yamaha Sportsman also. I’d like someone to break down the advantages/disadvantages, and the handling characteristics.
      Daniel
    • #51581
      5.50 fronts on 6″ wheels, 6.0 rears on 7″ wheels, Dunlop SL-4 18psi.
    • #51584
      Greg Wright
      We always found 450-5 fronts and 5.50-6 rears to be a good combo on most tracks.
      7″ wheels Gif?
      Greg Wright
      Rapid Racing Inc.
      Vintage B-Stock Pilot
    • #51586
      Glen Cherry
      Most of the Laydown guys I know are using the Hoosier 10.5×4.50-6 Enduro Tire on front and rear. The tire seems wider than most 5.0 wide tires and being a sportsman it is plenty of tire to hold the kart. I would mount them on 6″ wide wheels. I have used these at Daytona as well as Hallett, those are two completely different tracks and this setup of tires works great. The controls and opens are using wider tires on the rear.
    • #51590
      Yeah 6″ wide tire on a 7″ wide wheel, it worked good on my sit up sprint. Is that weird for a lay down?
    • #51592
      Glen Cherry
      To wide for a laydown kart! Situp sprint may work, but 5.5 on front would kill your speed and wear the arms out unless your on a twin.
    • #51597
      Daniel Justice
      7″ wheels Walt? Let’s not get carried away, I’m still new to 6″ wheels!
      But the 4.50-6 on all corners is one of the setups I was recommended also. How much would the handling change if you ran a 4.50 tire all around on 5″ wheels?
