Home Forums General Karting Discussion laptop buying question to use for mychron gps
Viewing 8 reply threads
    • #23859
      Jeff Myers
      just bought a mychron gps.i currently have a macbook so i need to get a windows laptop.what are the specs i need to run race studio.looking at a used acer aspire one with windows 7 starter… 4 gb and 500 gb harddrive.any help would be great.cheers
    • #23860
      Bill Boxell
      From the Race Studio manual
      Compatibility between Race Studio 2 and operative systems
      Race Studio 2 has been developed to guarantee the maximum working reliability and its correct working has been tested with the following operative systems: Microsoft Windows XP Microsoft Windows Vista and Microsoft Widows 7.
      All operative systems (Linux, Unix, Macintosh®) not indicated in this tutorial are to be considered not supported by this application.
      For any problem it is suggested to check http://www.aim-sportline.com website to verify if any recent news has been issued and, if not, to contact the technical support that can be found in home page at http://www.aim-sportline.com.
      I’m sure the Acer would work just fine.
    • #23865
      James McMahon
      Why not just bootcamp the macbook?
      Otherwise the most basic laptop will work fine. I used a P1 233Mhz laptop for a long time running Windows 2000.
    • #23872
      Jeff Myers
      thanks for the info guys!!! bought the acer downloaded race studio.ready to go.thanks again.cheers
    • #23886
      Will it work with Windows 8.1 ?
      There’s a Toshiba at Walmart for $328.
    • #23889
      Bill Boxell
      A friend of mine is running Race Studio and GPS Manager both on Windows 8. He hasn’t had any problems.
    • #23904
      Scott Newton
      FWIW, I run Race Studio using Windows 8.1 on my bootcamp’d Macbook.  Zero issues at all
    • #23942
      Stewart Willis
      2009 called and what its bootcamp back.  I run race studio on my Macbook Pro using VmWare.  Runs perfectly.  The only downside is that you cant format or update DataKeys using virtualization software..  At least I havent figured it out
    • #24001
      patrick j slattery
      It works fine on windows 8, don’t know about 8.1
