Home › Forums › 2-Cycle Racing › KT100 Ideal compression to be competitive.
- This topic has 30 replies, 7 voices, and was last updated 8 years, 3 months ago by FREDDY SANDOVAL.
AuthorPosts
October 7, 2014 at 3:30 pm #34977FREDDY SANDOVALParticipant
Can someone please tell me what a good compression reading should be for a super Sr pipe or can KT100 motor?
I keep hearing 125, 130 and 150 psi.
What would be an accurate compression number to be a decent/competitive motor?Thank you all in advanced. Fast Freddy.
October 7, 2014 at 4:03 pm #34980Jim SilverheelsParticipant
At least 160 psi. Ours were 160-165 psi using two different gauges.
October 7, 2014 at 4:27 pm #34981FREDDY SANDOVALParticipant
Jim
Thank you! That’s what I’m talking about
We’ve been getting our fresh engines back with about 95 psi to 120 psi, at the most.It’s no wonder we can’t finis on the podium in every race, we’re getting told it’s our chassis tuning, so we’ve tried every different set up we can gain any fraction and still lack of power.
Till we decided to check our compression.
Thank you for your help. Fast Freddy. -
October 7, 2014 at 4:47 pm #34985Jim SilverheelsParticipant
Freddy, I should have said 160 plus cut to WKA limits.. .025 squish and a tad over 11 cc’s cylinder volume at TDC. Try your gauge reading against another gauge to verify it’s not a bad gauge you have. chi wa wa my friend
October 7, 2014 at 5:26 pm #34987FREDDY SANDOVALParticipant
Jim
It’s all good, I understand
We’ve tried 2 different ones, including a new one from MAC tools
And it’s about the same readingsI’m only getting 90’s on mine (just broken in, at a very slow pace and gentle )
And 120 psi on my Son’s, with only 2 races on it, and carefully broken in also.Something’s telling me I’m dumping money where it doesn’t belong?
I would bet money that the guys running upfront have strong motors, producing at least 130 to 150 PSI? -
October 7, 2014 at 6:36 pm #34994Ted HamiltonParticipant
QUALITY guage neccesary, and a fresh battery on starter when turning it over to test… or so I’m told. The figures I was hearing on Bob’s were around 200, with ring job and/or rebore when it was below 140…
http://karting.4cycle.com/showthread.php?11090-kt100-port-timing — post #6
and depending on your application, this is interesting reading too:
http://eknclassic.com/viewtopic.php?t=98674&postdays=0&postorder=asc&highlight=kt100+open&start=0
2014 Praga Dragon / IAME KA-100 -
October 8, 2014 at 11:07 am #35032Jim SilverheelsParticipant
Ted I think the 200 figure is a compression volume of 9 cc’s.
October 8, 2014 at 1:12 pm #35040Ted HamiltonParticipant
Perhaps, but I think that thread was talking about to the bottom of the plug hole, not top (~2cc difference).
October 9, 2014 at 11:51 am #35079FREDDY SANDOVALParticipant
Thanks guys
I should have specified earlier
This is for a legal motor, and national level, not a hot rod motorWhat is the normal compression PSI I should be expecting from a reputable engine builder?
October 9, 2014 at 12:23 pm #35082Greg LindahlParticipant
Be certain you’re using a small engine compression gauge.
October 9, 2014 at 5:13 pm #35092FREDDY SANDOVALParticipant
Cool
Where can I buy one of those from? -
October 13, 2014 at 1:18 pm #35222brian downingParticipant
Google is your friend, check Amazon too
October 14, 2014 at 10:04 am #35283Paul LydaParticipant
I know that you should test with fresh battery in starter to get consistent/comparable numbers.
Also, Always been told to do it with Wide Open Throttle.
Question: Should you have fuel line hooked up or should carb be dry? Just dawned on me that may be some of differences that I see in my numbers.
October 14, 2014 at 11:16 am #35289FREDDY SANDOVALParticipant
Fuel line off, pulse line off and blocked off/sealed
I don’t know about wide open throttle, but I gess I could try that for learning
We’ve tried several motors from our other karts, that are set up the same way, with fairly fresh motors, and surely there is a difference, no matter how we put it.The point is that I don’t think you can race 2 stroke motors with low compression, especially when they only read 95 psi. That’s why I asked how many psi you guys are running on your motors? And this is for a spec pipe/can class at a local level. ( not open class )
October 17, 2014 at 1:15 pm #35447Walt GiffordParticipant
Some builders don’t hone the bore right. I’ve seen guys that just scratch it with a big spring loaded brake hone with no torque plates, don’t even measure and call it done. Loose as a goose because, as long as it doesn’t stick the piston they did a perfect job.
That being said, let us know what reading you get when you check it with open throttle.
41 years karting experience -
October 17, 2014 at 10:27 pm #35461FREDDY SANDOVALParticipant
Thanks, Walt
Well, I finally got engine back, and was said that there was nothing wrong with it, no leaks at all, and it all looked good.
I followed your advice to test it out of curiosity at wide open throttle, and with the pulse fitting plugged.
I got 12o PSI, I also tested again with the carburetor closed, and same readings
I don’t get it
I dropped off an engine with confirmed and double checked compression reading at 93 to 95 psi
And I get it back with 120 psi?
Anyhow, Walt. There is your answer to your wandering for the new updated readings at WOT
What do you thing? Any thoughts and pointers are always appreciated. Thank you.
October 18, 2014 at 8:21 am #35486Walt GiffordParticipant
Sounds like they put a new ring in it?
October 18, 2014 at 10:46 am #35497Jim SilverheelsParticipant
Fast Freddy, pull the head off and raise the cylinder off the piston. Take the ring off the piston and place it in the cylinder above the exhaust port. Hold the cylinder up to the light and see if you can see light around any part of the ring. This is called the light test. I bet the cylinder was honed out of round. Know anyone who can check the cylinder with a inside mic for roundness for you? The ring is free on the piston land also?
October 18, 2014 at 12:38 pm #35508FREDDY SANDOVALParticipant
Walt and Jim
I think both of you guys are right, I was just wondering about that, and now it all makes cense. There is absolutely no way that this engine miraculous gained 20 more PSI, unless like Walt said “may be a new ring”? Slap it on and thank you very much?
Jim, I think you may be right also with the trueness of the cylinder walls as well, and the light test. It’s just like when you do a straight edge on a cylinder head on a car, shine a flash light and you can crawl underneath.
We do run a spec class that switches from pipe to 4 can every other race for the old farts, like me. With 390 lbs. Pipe. 410 lbs 4 hole can, and a 3 disk L&T Wet clutch
And a spec class for the young guns Sr Super Sportsman at 360 lbs pipe and a 3 hole can 2 disk dry clutch.
That being said, for a spec class (club level) KT100. What PSI is most common?
Thank you all. Fast Freddy.
October 18, 2014 at 1:18 pm #35513Jim SilverheelsParticipant
160-165 PSI Freddy, quit screwing around and send the cylinder out to be checked for roundness and you’ll prob have to re hone/install new piston and ring .Yer positive the comp gauge is correct? Do the light test first. Easy fix.
October 18, 2014 at 4:35 pm #35517FREDDY SANDOVALParticipant
Ok, I won’t mess around, no more. I am taking in consideration what you’re saying, Jim. I do have my back up engine package to rely on, before I do my own inspection on this engine, and before I send the cylinder out.
Where can I order a good, accurate 2 cycle/small engine compression gauge kit?
Any suggestions or part numbers of the one I should get, and where to order it from?
October 18, 2014 at 6:28 pm #35521Jim SilverheelsParticipant
Fast Freddy, any auto parts stores have them. I had very very bad luck with the Harbor Freight ones. Go to a NAPA, Auto Zone, or Advance store and get one. They are all China made I believe and use a simple bourdon tube mechanism. If you run the engine and pull the exhaust off and see discolorization the the skirt ya got blowby with poor ring seal. Take the cylinder off and do the light test to verify it’s an out of round cylinder. Head gasket seals properly? If you had an air comp you may use a leak down tester to check ring seal also. Spend time reading on the net and go to You Tube for great videos. In the future you will laugh how easy it is to check this stuff. Grab the bull by the horn and learn to do this stuff and not send everything out for others to do. Just my take on it….chi wa wa
October 18, 2014 at 6:47 pm #35523FREDDY SANDOVALParticipant
We own an automotive repair facility, and I am a certified technician
We do have a fairly new compression gauge kit from Mac tools, and another one from Snap-on tools.
I just thought I needed a small engine compression gauge for these KT100 motors.
But yeah, I think from now on if I want something done right, I’ll do it myself, I just thought there was more science to keep those engines freshened up and legal.
What should be my ring gap, with a feeler gauge at the ends?
Thank you for all your advice
October 18, 2014 at 7:00 pm #35524Ted HamiltonParticipant
Clue me in to why a “small engine” gauge is needed — pressure is pressure, right?
October 18, 2014 at 7:16 pm #35525FREDDY SANDOVALParticipant
Ted
I only brought that up, since it was mentioned by Greg, so that’s why I wondered if I really needed one or not, I thought pressure is pressure too, I just had to go in with an open mind, as I’m learning 2 cycles too.
Not trying to re invent the wheel, I just thought that there may be something different here.
But in all honestly, if you don’t think I need one, then I gess i’m fine.
Please check the previous comments, I’m just trying to get advice here, not trying to prove a point.
October 23, 2014 at 3:26 am #35802brian downingParticipant
Install the ring in the cylinder and push it with the piston towards the upper end. The “gold ring” end gap clearance is in the .008 to .014 range. Yes, you check with feeler gauges, but don’t use shit tools from Sears, buy yourself a decent set of Starrett feeler gauges. They also make great 12″ finger feeler gauges that are good for checking piston to cylinder clearance, taper, etc.
Also make sure you install the ring with the “T” for top on the top side :)
October 23, 2014 at 10:13 am #35834FREDDY SANDOVALParticipant
Thank you, Brian
That is good info, and yes I only buy nothing but the best in tools
All Snap-On, Mac, and the best brands for precision tools, You’re right about that.Now, I’m new at this 2 stroke engine rebuilding. How do I order the correct ring? And do people usually trim or grind the ends to fit the feeler gauge? Or Do you have to get the ring that fits the feeler gauge?
Thank you, so much.
I think from now on I’m just gonna send my cylinders to get trued correctly and I think I’ll do the rest, it can’t get any worse than the quality work I’ve been getting by having a builder do it all. Lol
October 23, 2014 at 3:00 pm #35847brian downingParticipant
Order a ring from one of the respectable online dealers, call if you need to talk with them to make sure you’re getting the correct ring.
Usually one can get a ring .1 mm larger ring than the piston, so if for example your piston was oversized 0.5 to 52.50 mm, then you’d get a 52.60 mm ring and file equally from the ring ends until it fits to the gap spec ( .1 mm equals almost .004 of an inch).
October 23, 2014 at 3:09 pm #35850FREDDY SANDOVALParticipant
That’s awesome! Brian
Thank you.
When a decent full rebuild is done, Should I expect to see some 150 PSI? Or something like that? Right now I’m only getting 120 psi. It’s no wonder I can’t stay with the pack. Lol. -
October 24, 2014 at 1:18 am #35864brian downingParticipant
I can’t say for sure, but one of the tricks I learned was to test my compression once, then again after squirting some plain old 30 wt motor oil in through the plug hole and testing again.
If the compression jumps up, then the oil is helping the ring seal and yes, you’re not getting a good seal between piston and ring.
Aside from that, there are too many unknown variables.
I’d suggest buying a second motor anyway as they vary quite a bit from one casting to another.
You never know when you’re going to need a “B” motor, just in case ;) -
October 24, 2014 at 1:00 pm #35913FREDDY SANDOVALParticipant
Thanks, Brian
And yes, I do agree with second motor ( back up motors )
All of our karts at the shop have 2 motors for each kart
I currently have 2 newly rebuilt engines, sitting in my office, and that’s how I started testing all my engines, when I suspected I had no power,And there you go, my engine had low compression, so I started comparing everything we’ve been getting built.
Thank you for all your help and advice, You’re awesome!
AuthorPosts
