Home Forums 2-Cycle Racing KPV Stock Carb Settings
Viewing 6 reply threads
    • #45326
      Michael Monaghan
      Hi, I just purchased a KPV motor to try and run some f100 races. The motor runs great once on the track, but struggles to get going coming out of the pits for a hundred feet or more. A friend of mine turns in the low speed needle 1/2-1 turn in until he gets out of the pits, but he also has a blueprinted carb. Right now my carbs set at 5/8H and 1.5L (not sure about pop off pressure) and have a Horstman 3 pipe with 10/80 gearing. Does anyone have a rough approximation for what a stock carb should be set at, and do I to need to be turning in the low needle until I get out on the track? The other strange thing I’ve found is that the engine idles when I come back into the pits at 1800rpm. Not sure if that’s normal but all I’ve ever run is PRD.
    • #45338
      Anthony Siragusa
      Mike, it sound like you have a possible air leak, I would make sure all gaskets are good, and also doing a cleaning of the carb, do a rebuild on the carb, and start from there. Start with low speed at 2 full turns out and High speed at 1/2 turn, and move them in from there.
    • #45358
      Not sure how different stock to blueprinted settings would be, I would imagine they would be the same, but we always ran our KPV carbs at about 1.5 on the low and .25 on the high, and would open the low to 2-2.25 on the track once we got rolling. It won’t get off the grid unless it’s turned in.
    • #45403
      Gary Lawson
      +1 to TJs comments. Sounds like you need to back out the idle screw. Turning the low in to leave the pits and for starts is standard procedure
    • #45430
      Michael Monaghan
      I did find an air leak at the cylinder, so I threw some new gaskets on and rebuilt the carb while it was off. I won’t get a chance to run it till the next race though. From what I could find online though, a non-blueprinted carb runs at 1 1/2 low and 3/4 to 1/2 on the high. Seem to be a little different from all the blueprinted one, but then again, this is just going off of shop manuals.
    • #46633
      You have to check your pop off pressure and fulcrum arm height. There is a way to set up that carb so your engine will idle and still run good on the track. If your carb is set that way you’re going to need needle settings that are very different than conventional wisdom.
      If you can’t get going coming off the grid is it too rich or too lean? If you choke the airbox does it pick up or get worse.
    • #46638
      Stu Hayner
      Michael,
      Bring it in to the shop before you take it out to the track. I’ll help you with the carb and the settings. We can start the engine at the shop and tune it pretty close.
      MDG Karting
      1657 N Glassell
      Orange, Ca 92867
      714 928-KART (5278)
      Stu
