Home Forums General Karting Discussion Help Identify Kosmic Shifter Kart
Viewing 3 reply threads
    • #25190
      Chris Fraser
      Does anyone know what year and model this Kosmic shifter kart is?  Any experience with it?  A friend of mine has it and I would consider using it for rotax masters.
    • #25416
      Oliver Kell
      Chris,
      have a look at the homologation tag on the kart.
      it should be on the rear bar, behind the seat, in front of the axle.
      It will have a model and an expiry for the homologation.
      The kart may be upto 6 years older than that. Anything from ’03 to ’05 (which would be my best guess) is going to be essentially the same.
      Hipe this helps
      Oliver
    • #25636
      Carl Beavers
      Probably pre 2013 since in 2013 the new pedal system was standard.
      Follow the serial number and measure your tube diameters to find your answer.
    • #25816
      Ryon Beachner
      It’s either a 2004 or 2005 Kosmic T8. Primarily 32 mm, with the “B-Tech” system OTK used on that generation of chassis where one tube can be both 30, and 32 mm.
