2008 Italkart Supersonic V 32mm chassis for sale with many, many spares.
Looking to get into karting and need a deal, or maybe you’d like to do a one-off street race but don’t want to risk putting your regular kart in the dump? Then this post is for you. We are looking to unload a well-loved kart along with all the necessary spares to handle most of the ill fortune that can find you over the weekend.
This frame has been exclusively used at road race events (Mid Ohio, Road America, etc.), but for one race weekend at Concept Haulers Motor Speedway, so it has seen much less stress compared to a used sprint frame of the same age. It’s seen action with both Rotax and Leopard. The chassis comes with front brakes but can easily be switched to rear-only with included hardware. The frame has been updated to have: 25mm front spindles and KG EVO plastic (came with Unico); top and bottom eccentrics; locking top steering bushing to ease front end alignment. Full width steel and plastic rear bumper included with all mounting hardware.
Additional gear and spares include:
Front, Rear and 4th rail torsion bars.
Front 17mm spindles with hub sets for and without front brakes
Front 25mm spindles, new.
In addition to the 90mm rear hubs already on the kart, there is an additional 90mm set hubs, 65mm and 120mm.
Multiple spare bearings and bearing cassettes.
Two new plastic steering shaft bushings
Rear brake rotor, used.
Two shifter handles, two clutch handles and a shifter rod.
Tie rods, 12 total. 1-215mm, 1-220mm, 2-240mm, 1-250mm*, 3-270mm(one round + 2 with ends), 2-275mm, 2-290mm. *Current length rod on kart.
Spare rear crash bar, spare fairing support bracket, two nylon isolators for full steel rear bumper.
Used brake parts One set of rear blue (medium) pads. One set of rear red (soft) pads. One set of blue fronts. One set of red fronts. Four magnetic rear caliper pistons, four front pistons, two master cylinder pistons.
Three steering shafts. One black anodized 490mm quick change shaft, one chrome 490mm Italkart shaft and one 470mm SKM shaft.
Not pictured, one used rear axle (medium/standard), two sets of Douglas M series wheels with tires, chain guard, and two red chain guard straps. Effectively, we’re getting rid of anything that goes with this kart.
We are currently asking $1,000 for the kart and all the spares listed. The kart is stored in the greater Chicago area. Shipping would be at buyers cost.
Images for the kart and spares found here:
https://flickr.com/photos/15381595@N00/sets/72157648437171119
Additional info on this model can be found here:
http://italkart.com/chassis-2008.php
Please PM if interested.
Cheers & thanks
