Home Forums Classifieds Classifieds – Parts HUGE amount of Rotax parts
Viewing 2 reply threads
    • #38357
      Andy Finke
      Paypal for payment.  Free shipping if you spend $100 or more.  Actual USPS below $100 in sales.
      I can’t post a table, so the columns are a little out of line.  Sorry.
      Post in here to call ‘I’ll take it’ and then email or pm for details.   andy@jetkarting.com
      I have Engines with 2006 cyls, complete as well.
      part #    description            quan     price ea.
      201220    clear plastic radiator shroud    3     $26.41
      210331    top Power valve cover        1     $16.98
      222750    radiator cap            5     $23.18
      225015    airbox lower half        1     $19.22
      225025    airbox upper half        1     $26.74
      225031    carb socket — airbox-carb boot    2     $13.36
      225041    airbox intake port insert    2     $24.13
      225051    filter element            1     $10.86
      225061    filter support             2     $4.92
      230260    power valve oring        10     $1.87
      232365    clutch driver pin        6     $1.76
      233855    11t bushing            5     $7.93
      234435    balance gear            7     $35.06
      236871    12t driver            1     $29.31
      236872    13t driver            4     $29.31
      236873    14T driver            1     $29.31
      236877    11t driver            2     $28.21
      239030    power valve cover clip        4     $5.89
      239942    power valve spring        6     $3.82
      242141    airbox nut clips        8     $1.41
      242533    stinger nuts            20     $1.30
      242925    clutch driver nut        6     $7.33
      250231    power valve gasket        14     $3.04
      250271    Exhaust gasket            10     $3.55
      251123    battery box            2     $30.38
      251254    battery box clamp set(2 clamps)    4     $12.78
      251720    airbox bracket            1     $13.95
      251730    carb slide restrictor        1     $16.51
      251790    micro carb cap lock        2     $11.53
      253380    power valve lower manifold    2     $48.57
      260260    vent hose            5     $2.35
      260723    power valve bellows         2     $14.71
      261030    knurled drain plug        2     $22.56
      261270    slide bolt for cable        4     $11.40
      261427    carb cap            4     $18.26
      261550    splash cap under jet        7     $1.33
      264910    ground strap            8     $4.12
      265030    battery, Lion             2     $277.07
      265148    charger                2     $75.01
      265578    ignition coil (new)        2     $350.27
      265580    starter button            1     $18.70
      265592    ignition switch            1     $26.41
      266125    wire harness            2     $130.05
      267535    carb intake restrictor        4     $30.07
      267915    intake stuffer            1     $54.42
      268030    float 5.2gr            2     $13.17
      273076    Rotax Pipe, new style        1     $355.64
      273093    stinger, full pipe        4     $15.45
      273097    stinger, micro pipe        1     $21.74
      273971    exhaust manifold, SR        2     $28.23
      273972    exhaust manifold, micro & mini    2     $28.23
      276070    bellows spring tool        1     $55.93
      293834    dellorto gasket set        7     $15.86
      294812    starter bendix            1     $126.69
      295928    new radiator            1     $302.62
      296165    fuel pump rebuild kit        7     $16.37
      297983    steel iso mat kit        5     $26.17
      434840    starter gear/flywheel        2     $139.17
      440291    stinger bolts            20     $0.60
      441355    power valve stud        3     $5.40
      627340    outer driver washer on crank    5     $1.92
      627345    11t outer driver washer on crank  8     $1.92
      632415    Clutch needle bearing        8     $10.47
      634035    idle gear, 28/13        2     $13.59
      635850    water pump gear, 19t        2     $14.50
      651690    radiator mount post, aluminum    1     $14.15
      659907    clutch pack            1     $120.61
      659930    clutch drum            2     $46.50
      660221    battery top cover – plastic    10     $8.11
      660767    battery rubber matting        5     $12.70
      838255    power valve bellows spring     3     $1.68
      854440    power valve bellows piston    2     $15.31
      866708    plug boot            4     $12.75
      927057    clutch washer            5     $2.66
      939280    power valve bellows spring lrg    4     $2.90
      942950    driver nut on crank        4     $1.55
      950815    clutch oring            11     $1.38
      951791    hose clamp            5     $3.37
      974529    fuel line (rotax)        4     $15.41
      994483    fuel pump            2     $46.52
      265578used    ignition coil (used)    3     $210.00
      IW24    spark pug            5     $11.17
      IW27    spark pug            1     $11.17
      PKT Slide tool            3     $16.45
      8mm Isolation mounts        5     $7.67
      210345    starter cover            1     $8.52
      PKT Billet chain guard        1     $62.30
      PKT magnetic float height tool    2     $12.60
      PKT coil mount            1     $22.75
      PKT large jet holder        3     $20.65
      PKT small jet holder        1     $12.57
      Dellorto Jets, misc sizes, new    300     $3.15
      clutch holding tool        1     $45.50
      Rotax Pipe, old style, light use 2     $245.00
    • #38368
      Jeff Salak
      Andy,
      Ill buy clutch pack(659907), 1 drum (659930), Radiator mount post(651690),Airbox nut clips all 8 (242141), Radiator cap 1 of them(222750), a set of jets from 152-170, 2 clutch driver nut (242925), 2 clutch driver pins (232365),
      Im thinking about your radiator. That’s the New style with plastic flap?
      Let me know and Ill pay up!
      Thanks Jeff
    • #39332
      Dave Tooker
      Radiator available ? Flap style ?
