Home › Forums › Shifter Karts › Honda CR125 intake manifold and the Mikuni carb
- This topic has 15 replies, 7 voices, and was last updated 8 years, 8 months ago by andy graham.
AuthorPosts
July 22, 2013 at 1:12 am #4434Robert HorvathParticipant
UPDATE :
FYI Shifter Go Kart Guys,
For the open/modified
class of Honda CR125 Shifters.The very short fuel path direct fit Honda CR125 Shifter intake manifold for 38mm 2 flange bolt types of carburetors is all done .
It has a 11 degree right rotation angle
to to clear the kick start bump ( Carbs like the externally adjustable Mikuni 38mm Carbs work really well )No more rubber boots with right angle turns to disturb the fuel flow !
And even a more perfect fit when used in conjunction with the V-Force 3 Reed Cage box .
I’m getting this experimental test carb fitted up to the CR125 Honda.
Mikuni Super Butterfly Type SBN38mm Diaphragm Pump Carburetor
No jets to change ever (well almost never) as it has easy to get to externally adjustable low & high speed mixture screws just like the Vortex RoK-tt carb only a much bigger bore (38mm) to fit the CR125 Honda engine and the fuel pump is built right in too.I’m getting tired of always taking off the carb to change the high & low speed pilot jets and I don’t care for float types of carbs either.
These are one of the best performing and easy tuning carburators that money can buy.
see below:
Thank You
Bob
Robert Horvath
W352N6446 Road J
Oconomowoc Wi 53066 U.S.A. -
July 22, 2013 at 1:21 am #4435Robert HorvathParticipant
July 22, 2013 at 4:47 pm #4491James BellParticipant
Hey Bob,
Hope your daughter is doing better. Anyway I’m still interested in this carb set up. Are you finished with testing, fabing? PM me a price shipped. -
July 22, 2013 at 10:02 pm #4537Frank RapisardaParticipant
Hey Bob nice work, what is that carb off of ?
July 23, 2013 at 6:49 am #4553Chris ReinhardtParticipant
It look like a aftermarket only carb, no OEM application….
http://www.ebay.com/itm/Mikuni-Super-SBN-38-mm-38mm-Carburetor-Carb-Brand-New-/190459013132
CR
XV Racing Products
http://www.xvengineering.com/
July 25, 2013 at 3:29 am #4904Robert HorvathParticipant
On the Mikuni carb setup:
I posted this to see if there was much interest in this project and I see that there is…..So I’ll work up a price for the setup.
Would you karters get your own carbs off ebay like this one ? :
http://www.ebay.com/itm/Mikuni-Super-SBN-38-mm-38mm-Carburetor-Carb-Brand-New-/190459013132Or would you like the Mikuni carb, air box inlet adapter, primer system, gasket, nuts & bolts, throttle cable bracket , custom intake manifold and V force 3 reed box as a complete system ?
Probably not cheap when all added up ?
The intake manifold is about 1/2 inch thick someone asked.
The Carb is a generic replacement carb for my 1995 Polaris triple carb 750 cc watercraft (JetSki). see photo down below :
Each carb feeds each 250 cc cylinder.
The Jetski has such tremendous throttle response I thought I give it a try on my Honda shifter….It works well so far and I’ll keep you posted after much more track testing of the setup.
I do see now after track testing that I have to set the popoff pressure much lower.
Ocono Bob
Thank You
Robert HorvathW352N6446 Road J
July 25, 2013 at 9:50 pm #4994James BellParticipant
All im interested in is Mikuni carb, air box inlet adapter, primer system, gasket, nuts & bolts, throttle cable bracket , custom intake manifold. I can get the vforce reed cage myself. But for now this kit would work with a stock honda reeds and cage no?
July 30, 2013 at 6:28 pm #5383Broque WardParticipant
looks interesting. that sure will be a nice setup, the keihs are great but the jet changes suck.
does this carb have a fuel pump on it as well? looks like it but im not sure.
July 31, 2013 at 2:05 am #5425Robert HorvathParticipant
You asked “does this carb have a fuel pump on it as well? looks like it but im not sure”
The answer is > yes it does!
July 31, 2013 at 10:08 pm #5527Alan SheidlerParticipant
Do some sanctioning org’s prohibit carbs that have an integral fuel pump?
August 13, 2013 at 8:47 pm #6954Robert HorvathParticipant
Update > on the onboard
Carburetor Adjusting ToolFYI
I’m going see if I can modify for permanent installation a couple of these carb adjustment tools pictured down below to bring the Mikuni carb mixture low & high speed adjustment screws up to the front of the Honda CR125 cylinder head so maybe the driver could adjust the Carb on the fly instead of coming into the pits for a adjustment.
The carburetor adjusting tool has a flexible cable to easily access often hard to reach carb adjustment screws.
Carb Screw Adjusting Tool Part Number 53-999 $24.95 each.Here is a photo of two of them attached to the new Mikuni jet ski carb on the Honda Shifter.
Blue for the low speed mixture adjustment… and …Red for the high speed mixture adjustment.
Ocono Bob
Robert Horvath
W352N6446 Road J
Oconomowoc Wi 53066 U.S.A -
August 13, 2013 at 8:51 pm #6955Robert HorvathParticipant
The tracks around here in WI. USA don’t care when going though “TEC”
Ocono Bob
September 8, 2013 at 9:30 am #9319Robert HorvathParticipant
Results now are in
On using the :
Custom Honda CR125 intake manifold and the Mikuni carb setup
Hi back shifter guys.
It’s been about six weeks now that we have been using the new setup
I didn’t want to say anything before until the unit was thoroughly Race track tested.
The answer is easy ..JUST ONE WORD > Awesome Performance!
We have taken a full second off our own personal best time at our local track ( Badger Raceway Dousman wi.) and after hundreds & hundreds of laps with absolutely no Carb trouble at all.
A good lap time at Badger is anything under 38 seconds….We are consistently in the 37.20s with the Honda CR125/Mikuni now,
I’m not setup to “Retail a kit ” to the general public.
But I’m making arraignments now to sell it through a few of the better shifter kart shops and on line from them also.
It will be priced about on par with the Swedetech Honda intakes.
The complete intake kit would consist of the intake, all gaskets all, hardware,throttle cable, bar type throttle cable bracket, 38mm air filter/box adapter and to inc.this disclaimer below :
“As when installing any performance product, a degree of mechanical ability is required. If after reviewing the parts you don’t feel that you can properly complete this installation, take your kart to a competent professional. Proper installation and adjustment will save time, money and aggravation.”
Because of all the tight quarters I recommend installing the carb & and intake as one piece with a very long ball type allen wrench.
Then it’s easy to do.
I got so tired of always having to take the stupid Honda CR125 Keihin carburetor
off to change jets I’m taking a lot of them off the shifter Karts in our little classic shifter club and tossing them out or selling them….I think they are all JUNK.. pump arounds too….But maybe that’s just me ?Here below is a long story of what I’m doing for carbs instead …AND I’LL TELL YOU THIS SETUP REALLY WORKS WELL ON THE CR125s.
This below looks very clean and it solves all the fuel system issues.
Robert Horvath
UPDATE :FYI Shifter Go Kart Guys,
see all photos below:
Or a big bore Tilly is a good fit on the Honda too for short tracks!
Note > a primer bulb also for easy starts :Important note below :
Road America is a famous road course located near Elkhart Lake, Wisconsin
Here are the results of the first time out at Road America with the new intake set up.
I installed the kit on team Craig Hemmen / Bob Horvath (That’s me)
We ( Craig Hemmen age 61 the driver of Kart # 92 & me Bob Horvath the mechanic age 68) were competing all day at Road America) and of all the Pro shifter Karts (about 22) there today…We got fast time of the day and that gave us the Pole Position for the feature race and a First place Win in for our Honda class too.
The ICC shifters and the Honda’s all run together in one class due to the small number of each
Date 24-08-2013 13:36
Length 0.8000 Miles
Best lap time 44.463 In lap 4
Best speed 64.773 By competitor Craig
Hemmen/Bob Horvath
pos start no. competitor laps total time diff best time best lap best speed
1 Honda engine 92 Craig Hemmen 6 04:36.982 44.463 4 64.773
2 ICC type engine 65 Darrick Lang 6 04:54.457 17.475 44.690 5 64.444
3 ICC type engine 17 Dayton Bender 6 04:56.302 19.320 44.829 2 64.244Thank You
Bob
Robert Horvath
W352N6446 Road J
Oconomowoc Wi 53066 U.S.A.Honda;Mikuni;Intake;Manifold;Shifter;Carb
September 9, 2013 at 6:41 am #9389andy grahamParticipant
those SBN38’s were stock on the Sea Doo 785 engine back in the 90’s…there were a couple of companies that were known for modding those carbs to get some serious results…I remember Buckshot was kinda like the Swedetech of jetski racing when it came to carbs, and there was a company in FL called Red Top that changed the fuel distribution from a nozzle/sprayer to an angular distribution…I ran both set ups, I had better luck with the buckshots than the red tops, and I think they started as 38s and then had a bigger venturi pressed in as the mod….I bet if you search ebay for “sea doo xp carb” you’ll find plenty…there was also a place in Miami called PPG (Perry Performance Group) that did their own mod on the stock carbs on the 785s with good results….just food for thought
September 9, 2013 at 8:07 pm #9450Robert HorvathParticipant
Andy,
Thanks for the heads up.
I’ll look into both those carbs you mentioned and I’ll give Perry a call too.
Ocono Bob
September 10, 2013 at 3:32 am #9465andy grahamParticipant
in stock form on the sea doo they were black bodied carbs, the buckshots and the red tops were silver bodied like in your pic…I was thinking more about this yesterday — we never used the carb mounted fuel pump, they make (made) a block off plate to remove the pump and allowed you to run the big mikuni external pump…and I forgot all about the guys who were considered “The Best” when it came to pwc carbs — Novi. Buckshot got fancy and made manifolds, big (50mm) billet bodied carbs, linkage etc….Novi stuck to carbs and man were they awesome. Easy to tune. Pretty sure Buckshot is gone or has moved on…last I heard he was building dune buggies in SOCAL, but even that was a long time ago…the guy in FL making red tops has been gone for a long time also, I think the name of his company was True Cad Designs…they’re out there somewhere, hope this is at least a little helpful….good luck.
AuthorPosts
