Home Forums General Karting Discussion help understanding Aim gps with mychron 4
Viewing 6 reply threads
    • #38805
      Sebastian Sarmiento
      Hi everyone,
      I was told that the Aim GPS taps right into the Mychron 4. Then I was told by someone else that a special module is needed.
      Can somebody clarify this for me please?. Also I have a Mychron 3 gold and someone said that the map tracking it is like a GPS but not as accurate and that also I would need the G sensors.
      I don’t mean to make it even more complicated, but I would like to see in the computer, besides my lines, the G forces I’m pulling on turns. How can I accomplish this.
      Thanks in advance!!
      I wish you twice as much of whatever you wish for me. : )
    • #38808
      Sebastian,
      The someone else is right. The GPS05 module connects to a powered data hub that is sold with the GPS module. The data hub then connects to the M4.
      http://s1139.photobucket.com/user/backlite/media/schema_di_collegamento_mychron4_zps47522373.gif.html
      http://i1139.photobucket.com/albums/n546/backlite/schema_di_collegamento_mychron4_zps47522373.gif
      Not quite sure what you’re looking for here. The M3/Gold does have a lateral accelerometer. To get a lateral accelerometer on an M4 you would need to purchase an E-Box. IMO, if you’re getting the GPS module, getting an E-Box to go with it is not necessary. You should more than enough data from the GPS.
      When viewing your M3/Gold in Race Studio, enable LatAcc under MEASURES table on the Measures Graph. With a GPS module, enable the GPS_LatAcc measurement.
      Hope this helps a bit
    • #38821
      Sebastian Sarmiento
      thank Tony,
      Your explanations are always great!!!This helps a lot!!!
      Thanks man!! Just ordered a new M4 , A GPS (comes with dual data hub) and a Data key.
      That should be more than enough for what I need right now.
      Thanks again!!
    • #38841
      Matt Dixon
      Now crack open a beer and start learning…
      https://www.youtube.com/user/aimdata
      94y
      • #38862
        Sebastian Sarmiento
        Holly Molly, there are plenty of vids to watch, I may crack more than one lol. Thanks Matt.
    • #38853
      Christian Fox
      Sebastien, you can plug the GPS directly in to the Mychron 4 and not even use the data hub. The downside to this is you nuke the 9 volt battery in the Mychron very quickly, whereas the data hub method requires you to connect to an outside battery. I’m paranoid about running anything off of my kart’s battery, so I just use the direct plug-in method and carry a bunch of extra 9 volt batteries around in my toolbox. Tony’s example really is the best; the data hub is handy to have and makes downloading data and uploading track maps much easier. This winter I’m going to figure out a way to mount an RC car battery somewhere to power it. Most people claim it’s fine to run off of the kart’s battery, but I’ve had a few battery related issues and don’t want to take a chance.
    • #38861
      Sebastian Sarmiento
      Thanks all,
      Christian that means that the first guy wasn’t that far off. Interesting…. I found these ones, they last 3-5 years and are small enough, what do you think? Also not that expensive.
      Let’s see what does the fox say…lol, no disrespect intended. Just kidding
      http://www.ebay.com/itm/131376018931?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
    • #38867
      Sebastian Sarmiento
      Reading more I realized that the majority of people doesn’t want to hook this up to a 12v battery, especially (if you are running a TAG), the starter battery.
      So far it seems that mostly people run it off the 9v battery in the Mychron, but they use better or higher in mAh batteries. Like for example the one below, which has 1,200mAh capacity
      http://www.batterymart.com/p-bat-u9vl-fp.html
      Most of the Duracell 9v batteries have about 560 mAh. 150% more capacity sounds pretty good… May be the way to go, although the most comfortable option, may not be the cheapest one on the long run. (about $8 each when a mighty max will last 3-5 years and it will cost $21).
      I guess, like most of everything, it comes to preferences and the good thing is that either way you can always have a plan B if the battery dies at the wrong moment.
      Thank you all for helping me understand the basics of this set-up!
