Just getting into the karting scene. so I am learning as I go. I also have very limited knowledge about carbs.
I got into a bad car accident awhile back and have a bad leg Not only this but I do my karting myself, so setting the kart to idle will be helpful to me right now.
Here’s the problem, when I set the carb to idle, about 20 clicks (I have the carb where idle is set by turning the choke knob cw or ccw), the engine is bogging down when I get into the power band. I went 20 clicks back to normal and everything is fine.
Is this a jetting issue? Or do I need to adjust something else on the carb?
Thank You
