Home Forums TaG Help Identify Engine
Viewing 5 reply threads
    • #104477
      Todd Kageals
      Guys,
      I went to buy a shifter kart the other day, just so that I could have some fun on the track while my son is practicing in his LO206.  The very nice gentleman gave me another kart for free.  He identified it as a 125 TaG.  The only pictures that are similar that I can find are of an IAME100 TaG.  Can you check out this video and see what engine this might be?
      https://youtu.be/BO_LLE4bDIs
      Any information you can tell about it would be greatly appreciated.  I’m trying to decide what to do with it.  Supposedly it runs.
      Todd
    • #104506
      Steven Novikoff
      Looks like it’s an “EasyKart.  They were a completely spec kart with an air cooled motor by Iame.  The frame was made by Birel I believe.
    • #104524
      Todd Kageals
      Yeah….I know it’s an “EasyKart”, I was asking about the engine.  I don’t even know what it’s called so that I could get parts for it.  Not sure of the displacement, etc.
    • #104579
      Steven Novikoff
      It’s made by Iame.  It’s a most likely a 100cc motor.  They did make a 125cc and smaller ones for the kids as well.  It was probably one of the first air cooled motors with an electric starter.  Does that help?
    • #104586
      Todd Kageals
      Steven,
      I’m grateful for your response, but no, that’s not really helpful :)  I know it has an electric starter and that it’s made by IAME.  I was hoping someone could identify whether or not it’s a 125cc.  I also need a model for the engine as I would like to do the top end.
      Todd
    • #104587
      Clark Gaynor Sr.
      Hey Todd.  Pull the head and measure the bore, same with stroke.  A cheaper vernier should work fine.  You’re an educator so the math is pretty straight forward.
      Get a hold of one of the Tag engine folks and describe what you’ve got.  I’m sure one of them can get you started.  I’d try Paul Kennedy in Alexandria.  703-780-3224  Obviously don’t forget to through a carb kit in it too.  All the carb info should be right on it.  Having the carb bore size and number might help ID it.
      Good luck.
      Clark Sr.
