Contact Eric 626.232.9477 or e-mail eric@seventh-gear.com .
$4200 as shown or $3900 without MyChron. 100% freshly rebuilt with zero run time, just add fluids, break-in and go! Ships freight at $200 – $250 plus materials to most US states.
Details:
- 32mm Corsa (Haase) chassis
- Honda CR-250R engine is freshly case-up rebuilt with all new gaskets, new oil & water seals, new water separator, new main bearings, all new piston / top end, and secured (open) exhaust valve.
- AIM MyChron 4 data system
- Front / rear Haase Runner brake system with OTK self-adjusting master cylinders
- New KG Evo bodywork
- New Righetti CIK rear bumper & brackets
- New X-Seat size Large
- 50mm OTK “H” axle
- OTK 50mm x 90mm hubs
- CIK 5″ x 130mm / 210mm aluminum wheels
- New Maxxis SLR 4.5 / 7.1 tires
- Righetti heel stops & pedal grips
- New non-hardening fuel line
- New large-capacity fuel filter
- Overhauled Mikuni Rectangular fuel pump
- X-Stream air filter
- 39mm Mikuni TMX carburetor
- New RLV 250H pipe
- New RLV 1-1/8″ ShifterMax silencer
- New Alden engine mount
- Original KG radiator with shade kit
- New steel drive & axle sprockets
- New DID #428 chain
- New Courtney Concepts shift arm
- New Righetti shift linkage
</div>
