Home Forums General Karting Discussion GPS setting question
Viewing 2 reply threads
    • #45461
      Brad Johnson
      When you go to a new track can you set your GPS at the start line without following that with an actual lap? Say before practice or anything, walk the kart to the line and set the “beacon” and then when laps start the Mychron picks up the spot. Ive had on again off again luck with the GPS so looking for some tips. Ive also found that the track width setting affects the operation.
    • #45462
      Matt Dixon
      Yes. Hold down the On/View button untill GPS Data appears.
      Go to S/F line press OK then hit View to exit
      94y
    • #45463
      Brad Johnson
      Thanks for the help.
