Home Forums Tech Talk Dry Clutch Clearance (Patriot)
Viewing 2 reply threads
    • #39127
      How much clearance do you need between a Patriot dry clutch and the third bearing arm. I made a spacer so the third bearing comes out to the end of the starter nut and that gives me .400″. Is that enough clearance for the weights to swing out?
    • #39371
      Michael Curry
      Walt,
      Remove springs and pivot lever manually to check clearance. Pull crank outward to accommodate end play of crank and give yourself another .050″ for safety. Your initial .400″ sounds like plenty.
      Mike
    • #39372
      I called the vendor and he said if you can stick your thumb in there you’re good lol.
