Home Forums Classifieds Classifieds – Parts DR Chassis Parts
This topic contains 4 replies, has 2 voices, and was last updated by  Ron Artinger 5 years, 3 months ago.
  • #16544
    Kevin Sturgill
    DR Chassis Parts for sale
    Mag Wheels – Front 130MM x 5 Rear 180MM x 5   Qty: 6 sets   $100.00/set
    Alum Wheels – Front 130MM x 5 Rear 180MM x 5   Qty: 2 sets   $80.00/set
    Low Volume Mag Wheels – Front 130MM x 5 Rear 180MM x 5   Qty: 1 set  $100.00/set
    50MM Axles
    #1  Qty: 1  $50.00
    #2  Qty: 2  $50.00 each
    #6  Qty: 2  $50.00 each
    50MM Sprocket Hub   Qty: 1  $25.00
    50MM Rear Short Hub  Qty: 4  $50.00 each
    50MM Rear Med Hub  Qty: 4  $50.00 each
    25MM Long Front Hub  Qty: 4  $50.00 each
    Master Cylinder  Qty: 1  $75.00
    Rear Brake Caliper Rebuild Kit  Qty: 2  $10.00 each
    Mater Cylinder Rebuild Kit  Qty: 1  $10.00
    Brake Pads  Qty: 1 set  $25.00
    25MM Front Spindle  Qty: 2 Right and 2 Left   $100.00 each
  • #16567
    Ron Artinger
    Is the rear caliper a CRG V05?  Also, what is bolt pattern on the wheels standard metric or CRG pattern?
    Thanks!
    -Ron
  • #16570
    Kevin Sturgill
    I only have a rear caliper rebuild kit for the standard caliper that comes on the S97
    The wheels are all DR/CRG bolt pattern
  • #16630
    Ron Artinger
    I will take a caliper rebuild kit. what color are the wheels?  Can you send pics of the wheels and hubs?  Ron.artinger@ gmail.com.
    -Ron
  • #16819
    Ron Artinger
    Still for sale?
    -Ron
