Home Forums Classifieds Classifieds – Kart Packages DD2 Xator Only $8595 GREAT CHRISTMAS PRESENT!!!
    • #17696
      Teresa
      Blocked
      DD2 Xator GREAT CHRISTMAS PRESENT!!!
      This kart is specifically designed for the DD2 Rotax class. It’s a non-shifter kart with 4 wheel pedal operated brakes. Ths is the same design as the CRG kart.
      This kart is usually available only through special order. It was built for a customer that didn’t buy it. It has zero hours on the motor.
      32mm Chassis
      40mm Axle
      vented hydraulic braking system
      floating cast iron brake disc
      Complete Kart & Motor $8,595 (Retails for $10,900)
      Call Robert Finley for questions or more details (972) 839-3414
