Have a out dated 08? CRG KT1 chassis with ven99 brakes. I’ve rebuilt the master and caliper, bleed with the proper tools and fluid but the system just sucks for TAG senior, its just to over worked for such class. So forward on.
I recently acquired a complete 2014 CRG KT1 besides the frame. I was hoping to incorporate the ven 05 brakes onto my chassis but quickly realized the cassettes are 4 bolt not 3 like my frame. Considering the caliper bracket bolts to the cassette and i cant use the 4 bolt cassette i think im screwed. So now after a little more searching i see the Ven04 uses a bracket that appears to bolt to 3 bolt OR 4 bolt cassettes depending on the bracket. Im wondering can i get the ven04 caliper bracket and ven04 bearing cassette spacer and finally be able to bolt it all up?
If anybody has ven04 stuff id very much appreciate if i could get certain dimensions on the caliper bracket and cassette spacer holes. The only reason im trying to do this and not buy a new frame for the newer crg parts i acquired is because i simply do not have the money nor feel its worth it to spend $2,200+ on a new frame when im not going to be a front runner for awhile (im running a my09 leopard as it is compared to the x30 people until i can really be competitive)
